mallman2
Jan 10, 2016Aspirant
Cannot access wifi using other access points
WNDR4500v3 with firmware V1.0.0. I32 I purchased this router on dec 25 2015 to replace a dead linksys router. The router feeds a 16 point switch from one of 4 ports. I have one win 7 pc connected ...
- Jan 13, 2016
Figured it out it was windows network and sharing manager marking the connection as unknown.
In advanved sharing setting I had to change to use user accounts and passwords to connect to other computers
Then all the problems went away.
No more dropping connection and having no internet connection.
mallman2
Jan 13, 2016Aspirant
Retired_Member
Jan 13, 2016Good for You!
Thanks for the update!
