juliee78
Jun 24, 2026Aspirant
Cannot access
192.168.1.1 is the default router IP ? I mapped it to something else 192.168.0.180. If I go there after setting up wifi 2.4Ghz and 5Ghz + reboot, I am usually redirected to a page to configure the a...
Jun 24, 2026Guru - Experienced User
juliee78 wrote:I also have the same question.
I suspect you are talking about a different router though, since the R6700v3 is long past end-of-life.
Open a new discusssion thread and let us know there what model you have - that is better than piling on to a year-old thread.
