pookie525's avatar
pookie525
Cannot change security settings--revert back to old settings
Please be patient with me as I am not that great at this stuff.  I have updated my firmware to the latest version.  I currently have the security setting at WPA-PSK (TKIP) + WPA2-PSK (AES) and I was reading today that I should never have that.  I tried logging into the router to change it to just the WPA2-PSK (AES) option but when I go to do that and push apply, it automatically changes it right back to where it was.  I tried doing it several times and it always changes it back.  Please help me.  I don't want to have to buy a new router as this one is working great.
I don't know if it matters or not but I am referring to the first band (the 2.4 Ghz one or whatever it is).  The second one is on WPA-PSK (AES) already.  If someone can please help me, I would really appreciate it.  Thank you.
  • I think I finally figured it out but thank you for your help.  I had to turn off all security, apply the settings, restart the router, and then go back and put the security on.  I read about people having similar issues and turning off the security temporarily seemed to correct the issue so I gave it a shot and it now showing up the correct security setting.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello pookie525
    Welcome to the community!
    It seems that it's not saving the settings correctly.
    I suggest that you try to reflash the firmware of the router first.
    You may download and follow the instructions here.
    After it successfully loaded the firmware, you may need to factory reset the router.
    Factory reset will wipe out all the settings on the router and therefore you will need to reconfigure.
    See the link below on how to reconfigure the router.
    I cannot access the Internet with my NETGEAR router
    • pookie525's avatar
      pookie525
      • ElaineM's avatar
        ElaineM
        That's great news!
        Thank you for the update.
