Brodstein
Nov 23, 2020Aspirant
Cannot connect iMacs to the Internet via Ethernet
I have three iMacs in different locations in my home office. I have a Netgear Cable Modem connected to Comcast, the RBR20 Orbi Router and two Orbi Satellites. The two Satellites are connected to the ...
antinode
Nov 23, 2020Guru
> [...] I have a Netgear Cable Modem [...]
_Which_ "a Netgear Cable Modem"? Look for "Model" on the product
label.
> [...] I prefer to have the iMacs connected to the Internet with
> Ethernet, [...]
Ok. And to what, exactly, did you connect what? Connecting multiple
devices to your (unspecified) "a Netgear Cable Modem" would probably be
a mistake (which might account for this behavior).
> Network (Ethernet).pdf
That shows that the Mac's Ethernet interface is connected to
_something_ (no "Status: Cable Unplugged" complaint), but whatever it
is, it's not providing valid IP parameters using DHCP.
- BrodsteinNov 24, 2020Aspirant
Hi Antinode,
I very much appreciate your attempt to help — thank you!
Please see the attachment, which I think will answer your questions. I have included all of the model numbers, and how everything is connected via ethernet cable. My objective is to have the iMacs connect to the Internet via Ethernet instead of WiFi. This is exactly the same way everything was wired when I was using Apple Extremes, and that worked fine.
As I mentioned in my last post, the WiFi is working fine from the Orbi Router and two Orbi Satellites, but I want to go back to connecting to the Internet via Ethernet. (The problem message in System Preferences (Network) is "Ethernet has a self-assigned IP address and will not be able to connect to the Internet.")
Thanks again.
David
- antinodeNov 24, 2020Guru
> [...] how everything is connected via ethernet cable. [...]
Can't work (or be true) as pictured. You should have a separate
Ethernet cable from each client device to the switch. See the Orbi WiFi
System User Manual, "Figure 3. Ethernet backhaul connection using a
switch". If that were done, then I'd expect things to work.One thing which you might try is to start with a simpler arrangement,
with a minimal set of devices (like, say, modem, router, Mac), and get
_something_ to work. Then start adding complications (until things
fail).
Some of these devices have LED indicators, which I can't see from
here.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.- BrodsteinNov 25, 2020Aspirant
I very much appreciate your response, and if this gets to be too much of a pain in the neck for you, just let me know.
Initially I was puzzled by your comment, "You should have a separate Ethernet cable from each client device to the switch." Then I realized that I had created the wrong impression with my diagram, which I have redone and attached. There is in fact a separate Ethernet cable that runs from each port on the Switch to each device.
Other than the change of the Router, this is exactly the arrangement that worked with the Apple Extremes. (I decommissioned those because I had them for a long time, and wanted a more up-to-date mesh system.)
If you have any other ideas I would love to hear them, but I don't want to prevail on your time.
Happy Thanksgiving!
David
