daniig0405's avatar
daniig0405
Follower
Dec 31, 2019
Cannot connect router- Do not remember router name or password
I have a Netgear CM500 that I cannot remember the network name or password to. I cannot currently connect it to my laptop as I do not know what the network name is & I have tried everything even sett...
  • antinode's avatar
    Dec 31, 2019
    > password to. [...]
       A CM500 is a modem, and not a router, so it has no "network name" (or
    any wireless-network capability).
    > [...] I cannot currently connect it to my laptop [...]
       "connect" how?  Are you talking about a wireless connection?
       "cannot" is not a useful problem description.  It does not say what
    you did. It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       Is this a new installation, or a problem with an existing
    installation, or what?  Is there some kind of router involved?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.
    > [...] I have tried everything [...]
       Think, for a moment, about how little useful information that
    non-description conveys to the non-psychics in your audience.
