davenicsnr
Feb 10, 2021Aspirant
cannot connect second extender ac750 to network
Tried to connect with simple wps set up but failed. So followed previous extender connection instructions and used ethernet cable between extender & laptop. First effort failed part way through pro...
- Feb 12, 2021
If you didn't reset the original it should connect. But you can always try rerunning setup on it
Feb 10, 2021Guru - Experienced User
You're setting up a 2nd one?
Did you shut off the 1st one during setup?
What router are you connecting it to?
- davenicsnrFeb 10, 2021Aspirant
Yes setting up a second extender. N300 already installed on 1st floor
No I didnt shut N300 down
Vodafone broadband wifi hub model THG3000
- plemansFeb 10, 2021Guru - Experienced User
try shutting off the 1st one while doing setup on the 2nd. Then once its setup, power the first back on
- davenicsnrFeb 11, 2021Aspirant
Shut off ist floor extender but didnt make any difference.
I did finally connect to the set up gene with ethernet cable and was able to connect laptop and other devices to the new extender but after several attempts. Authentification problems shown on mobiles.
However the extender wps led is not turning on so I assume I have no security? Have I missed something in the set up?
