davenicsnr
Feb 10, 2021Aspirant
cannot connect second extender ac750 to network
Tried to connect with simple wps set up but failed. So followed previous extender connection instructions and used ethernet cable between extender & laptop. First effort failed part way through pro...
- Feb 12, 2021
If you didn't reset the original it should connect. But you can always try rerunning setup on it
davenicsnr
Feb 12, 2021Aspirant
Reconnected original extender N300 on 1st floor but could not connect to router. Is it possible I need to programme again after trying to set up ac750?
I had not removed the N300 initialy when trying to set up ac750. Could this be the problem? Could one have effected the other.
Spent the last 2hrs on the phone with vodafone support. They advise router is ok following tests.
They are calling me back in 2hrs after I have contacted you for advice
Feb 12, 2021Guru - Experienced User
