Mardo
Aug 09, 2016Tutor
Cannot connect to internet
Hello My new wifi router Netgear WNDR3700v5 N600 wont connect via WAN port to internet. IP, DNS, MASK etc. is set all right.The internet connection button on router has green light. The status of i...
- Aug 11, 2016
It was just my carelessness, I was using Netgear original MAC and ISP fixed on their device my IP adress for MAC on old TP link router...I just rewrite it and everithing start working.
michaelkenward
Aug 10, 2016Guru - Experienced User
I assume that this router is connected to a modem of some sort. If so, what modem?
Perhaps you have to reconfigure it, or the router, to work together.
TheEther
Aug 10, 2016Guru
+1
I see a couple of items of concern about the Internet Port in the 2nd screenshot.
- 10.9.76.6 is a private IP address. This is usually a sign that the modem has a built-in router. It's usually not a good idea to connect two routers in series. You should either disable the router in the modem or reconfigure the WNDR3700 as an Access Point.
- The Internet Port connection type is listed as FixedIP. Unless the ISP instructed you to use a specific IP address, you should change the Internet settings to obtain its IP address dynamically.
- MardoAug 10, 2016Tutor
Thank You a lot...I will try to reconfigure it as AP
