lcaesar
Sep 06, 2017Initiate
Cannot connect to netgear router with Philips Hue
Cannot get internet connection on hue wireless lights with netgear router
- Sep 07, 2017
> [...] I plug the Phillips hue as directed into the netgear [...]
Does this "Phillips hue" have a model number? "as directed" by what?
TheEther
Sep 07, 2017Guru
Can you clarify your problem? Hue lights don't connect to the Internet. Instead, they connect to a Philips Hue bridge, which connect to your router with an Ethernet cable. The lights don't use Wi-Fi.
Are you, perhaps, having trouble using the Hue app on your smartphone?
- lcaesarSep 07, 2017Initiate
The issue is that when I plug the Phillips hue as directed into the netgear for a internet connection there are three lights that are supposed to be solid. Only two lights are solid and the Internet light just blinks which means it's not connecting to internet. Is it possible I need a plug play (upnp) for this to work?
- antinodeSep 07, 2017Guru
Does this "Phillips hue" have a model number? "as directed" by what? - TheEtherSep 07, 2017Guru
According to this troubleshooting page, Hue only needs an Internet connection if you want to control the lights while away from home.
You might want to try their other suggestions.
