lcaesar
Sep 06, 2017Initiate
Cannot connect to netgear router with Philips Hue
Cannot get internet connection on hue wireless lights with netgear router
- Sep 07, 2017
> [...] I plug the Phillips hue as directed into the netgear [...]
Does this "Phillips hue" have a model number? "as directed" by what?
lcaesar
Sep 07, 2017Initiate
The issue is that when I plug the Phillips hue as directed into the netgear for a internet connection there are three lights that are supposed to be solid. Only two lights are solid and the Internet light just blinks which means it's not connecting to internet. Is it possible I need a plug play (upnp) for this to work?
antinode
Sep 07, 2017Guru
