Tapps's avatar
Tapps
Cannot Connect to R6100 Router
AC1200 WiFi Router Model R6100 (wasn't an option in the model section)   Today, setup Spectrum modem, verified it's working, connected the router and nothing can connect to it via wifi or etherne...
  • Tapps's avatar
    Tapps
    Dec 08, 2018
    Yeah...idk what happened but it works now...i guess i hit the correct number of factory resets cause apparently the third time was the charm...after the factory reset, gained access to routerlogin somehow and followed the setup wizard which required toggling power to the modem one last time, then everything worked
