Tapps
Dec 09, 2018Aspirant
Cannot Connect to R6100 Router
AC1200 WiFi Router Model R6100 (wasn't an option in the model section)
Today, setup Spectrum modem, verified it's working, connected the router and nothing can connect to it via wifi or etherne...
- Dec 09, 2018Yeah...idk what happened but it works now...i guess i hit the correct number of factory resets cause apparently the third time was the charm...after the factory reset, gained access to routerlogin somehow and followed the setup wizard which required toggling power to the modem one last time, then everything worked
Tapps
TaterSalid
Dec 09, 2018Virtuoso
Congrats. It is always a simple fix. The question is, how many simple fixes must be tried before the correct one is found?
