jhpackard
Jun 25, 2017Aspirant
Cannot connect to router WNDR3400v2/N600
- ASUS laptop - Win 7 - Latest router firmware I suddenly cannot connect wirelessly to the router. This followed a rerouting of power cords. The router failed to power up. After letting it sit...
- Jun 26, 2017
You can try and do a hard reset by pressing the pinhole with a paper clip for 30 seconds and re-doing your configuration. Also try a different power adapter if its having a power issue.
ElaineM
Jun 26, 2017NETGEAR Employee Retired
Welcome to the community, jhpackard
Can you check if the wireless lights are lit?
You may follow the steps from the article below.
- wcalifas831Jun 26, 2017Prodigy
- jhpackardJul 03, 2017Aspirant
wcalifas831 - The hard reset and reconfiguration fixed the problem. Obliged!
