jhpackard
Jun 25, 2017Aspirant
Cannot connect to router WNDR3400v2/N600
- ASUS laptop - Win 7 - Latest router firmware I suddenly cannot connect wirelessly to the router. This followed a rerouting of power cords. The router failed to power up. After letting it sit...
- Jun 26, 2017
You can try and do a hard reset by pressing the pinhole with a paper clip for 30 seconds and re-doing your configuration. Also try a different power adapter if its having a power issue.
wcalifas831
Jun 26, 2017Prodigy
jhpackard
Jul 03, 2017Aspirant
wcalifas831 - The hard reset and reconfiguration fixed the problem. Obliged!
