joedjo
Dec 22, 2016Aspirant
Cannot connect to routeur
Hello, Impossible to connect my pc (portable windows7) to my routeur. I get the message: The connection has been reset The connection to the server was reset while the page was loaded. The...
- Dec 30, 2016
Hello
I think I will not hear from Kaspersky for several days.And I had a little time today.
So I uninstalled Kaspersky Internet security.
And now I have access to my router
I reinstalled Kaspersky and everything is ok (until now....)
I will give you the answer from Kaspersky's technical service.Thanks you very much for your help
Happy new year!
ElaineM
Dec 23, 2016NETGEAR Employee Retired
Welcome to the community, joedjo
I suggest that you factory reset the router then reconfigure it manually.
Make sure to use a wired computer when reconfiguring the router.
- joedjoDec 23, 2016Aspirant
I have already reset the routeur
All devices are connected to internet (internet radio, camera, my laptop)
They all appear under netgear genie!
If I connect my laptop to the router with a cable I get the same message! (and no login screen)
I think there is a problem on my laptop ...?
Because if I try to connect to the routeur with my smartphone I get the login screen!- StephenBDec 23, 2016Guru - Experienced User
Are you using the router's IP address in your browser or http://www.routerlogin.net?
Maybe try them both.
Also, is this a new set up, or was the router working before?
I tried both methods via 10.0.0.1 and http://www.routerlogin.net?
I get the same message each time as soon as I click on one of the 2 links.I don't know if the parameters are "new set up" or "router working before" since I can not connect
When I do a reset it is a new set up no?
