OliB
Jul 22, 2018Aspirant
Cannot enable LAN file sharing (NOT USB/ReadySHARE) between Windows 7 PCs
I have two Windows 7 PCs connected to the LAN ports of a R6400v2. There is nothing in the USB port. The PCs are set up to view the LAN as a Work network, and shared folders are set up on each PC with...
- Jul 23, 2018
> [...] The PCs are set up to view the LAN as a Work network, [...]
Is that true even after you start swapping routers?
antinode
Jul 23, 2018Guru
OliB
Jul 23, 2018Aspirant
Yes, it is. Windows will usually assume a new network as public, in which case sharing is off, but I am checking that and am manually setting it back to Work if needed, with sharing enabled.
