stpham168
Feb 05, 2021Follower
Cannot establish wifi signal on Netgear extender to Fios router
Following the Netgear instructions to connect the NetGear extender to the new router Verizon Fios WiFi 6 but failed after may attempts (5 times). No LED appeared on the Link status on the NetGear E...
Feb 06, 2021Guru - Experienced User
Which fios router is it?
Are you using the installation assistant on the EX8000?
where is it failing in the process?
