cwuestusa
Mar 26, 2017Aspirant
Cannot find option for Firmware update when I login to my R6400 AC1750 wireless router
When I login to my R6400/AC1750 Smart WiFi Router from my MAC computer using www.routerlogin.net, I cannot find a function to update my firmware on my router, or search for a new firmware version or ...
- Mar 27, 2017
Yes it was in advanced setting >> administration >> router update, thank you so much for helping me find it!!!
VE6CGX
Mar 26, 2017Master
After logging into the router where are you looking? It should be in the advanced setting >> administration >> firmware
- cwuestusaMar 27, 2017Aspirant
- TxAnd_48Apr 18, 2017Aspirant
I can not find an Advanced Settings function on my router.
- DexterJBApr 19, 2017NETGEAR Moderator
Hi TxAnd_48,
You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24217
http://kb.netgear.com/app/answers/detail/a_id/23960
Dexter
Community Team
