mbehum
Mar 09, 2021Tutor
Cannot get replacement wireless routers to connect to internet
I am trying to replace my old wireless router (a 12-year old Rangemax WPN824 v2) because that router caps my download speed at ~20Mbps. That wireless network originally used WPA2 security with an ac...
antinode
Mar 09, 2021Guru
> [...] I do have inernet from my source modem just fine [...]
What, exactly, is your (unspecified) "my source modem"?
> [...] I can see bth routers on the list of available networks, [...]
Which "bth routers"? At the same time?
> [...] Any pointers would be very much appreciated. [...]
Have you tried the obvious?:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Further reading might not hurt,
either.
- mbehumMar 09, 2021Tutor
Responses below
Re: Cannot get replacement wireless routers to connect to internet> [...] I do have inernet from my source modem just fine [...]
ARRIS Surfboard Surfboard 3.0
No each router tried independently. Pardon the typo.
Yes ... yes I have
- antinodeMar 10, 2021Guru
> Yes ... yes I have
And then what? From here, with my weak psychic powers, I can't see
any of the LEDs on any of your devices. I also can't point a web
browser at any of them, and try any of the stuff which you might find
under "Troubleshooting" in a User Manual. Given no information beyond
"doesn't work", it's tough to make specific suggestions.
