amritahuja
Jun 21, 2016Tutor
Cannot go to router login page on WiFi
I am using netgear WiFi router. WiFi is working fine, internet is working fine but I cannot go to the login page without connecting the Ethernet cable. I have to connect it with cable to change the p...
- Jun 29, 2016No hit and trials.. I unchecked the WiFi isolation box and the problem got resolved. I found it myself.
VE6CGX
Jun 21, 2016Master
What do you mean by sayung 'without connecting Ethernetr cable' Are you using Genie? Manually tried using router ip address
with browser?
