amritahuja
Jun 21, 2016Tutor
Cannot go to router login page on WiFi
I am using netgear WiFi router. WiFi is working fine, internet is working fine but I cannot go to the login page without connecting the Ethernet cable. I have to connect it with cable to change the p...
- Jun 29, 2016No hit and trials.. I unchecked the WiFi isolation box and the problem got resolved. I found it myself.
amritahuja
Jun 21, 2016Tutor
If I connect the Ethernet cable n type the IP it goes to the router page
- VE6CGXJun 21, 2016Master
Generally router GUI page accessing via wireless is not a good practice. Same with trying to update firmware using wireless.
Security and signal loss, etc. issues. So you are connected via wireless and when you enter the ip address on you browser
what happens no error message?
