amritahuja
Jun 21, 2016Tutor
Cannot go to router login page on WiFi
I am using netgear WiFi router. WiFi is working fine, internet is working fine but I cannot go to the login page without connecting the Ethernet cable. I have to connect it with cable to change the p...
- Jun 29, 2016No hit and trials.. I unchecked the WiFi isolation box and the problem got resolved. I found it myself.
amritahuja
Jun 21, 2016Tutor
But connecting the router is a tough job, I mean I misplaced my Ethernet cable recently n had to search my place to change the password. While connected through WiFi if I enter the router IP I get the same message that we get when we type any url without the internet. ' the page cannot be loaded'. Is there any setting in the router that we have to enable to access the router login page while connected through WiFi ?
Thanks in advance for the help
- VE6CGXJun 21, 2016Master
Occassional use for wireless is OK I guess. Tried different browser? Just to be sure clear the browser cache. Also see if you can ping the router. Also you try this command with 3 different switches 'ipconfig /release' 'ipconfig /renew' 'ipconfig /all' and try again.
