amritahuja's avatar
Jun 21, 2016
Cannot go to router login page on WiFi
I am using netgear WiFi router. WiFi is working fine, internet is working fine but I cannot go to the login page without connecting the Ethernet cable. I have to connect it with cable to change the p...
  • amritahuja's avatar
    Jun 29, 2016
    No hit and trials.. I unchecked the WiFi isolation box and the problem got resolved. I found it myself.
