pcg1
Dec 17, 2020Follower
cannot log into n900 model WNDR4500v3 after factory reset
I have a Netgear N900 model WNDR4500v3 that is just out of warranty. After a power outage the router reset itself and the WiFi works fine with the default WiFi password. However, I am now unable to a...
wcalifas
Dec 24, 2020Prodigy
You could always try reinstalling the firmware using the tftp method. There's videos on "how to unbrick a router" on youtube. I know yours isn't bricked but it won't let you login so I'd try using the tftp method to see if it changes things and let's you login.
