quasi_stomach
Nov 21, 2020Follower
Cannot log into RBR50 because of ad for Circle
I cannot log into my Orbi router because it shows an ad for something called Circle instead of the login prompt. If I close the ad, I just get a 400 error. I cannot configure my router or install a firmware upgrade either, because I cannot log in.
1 Reply
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
