n91745
Aug 14, 2016Aspirant
Cannot Make Wired Connection to R6300v2
I had a webcam w/ a static address 192.168.1.20 plugged into my Netgear R6300v2, and it worked just fine for months. Then one day it stopped working (the router may have been rebooted after a power o...
- Aug 15, 2016
Thanks for the advice. I did that -- and it was very solid advice -- but it didn't help.
What turned out to be the problem was that the ethernet jacks 1 & 4 were not working, whereas 2 & 3 did. Weird. As soon as I plugged in my webcam to jack 2 or 3, everything worked as expected.
Retired_Member
Aug 15, 2016reset to defaults and Use address reservations for the camera. The router will assign same IP all the time to it without You having to change the DHCP range.
set camera to DHCP
- n91745Aug 15, 2016Aspirant
