Texasdave88
Sep 25, 2021Aspirant
Cannot reconnect ex2700 to wireless network
Ex2700 has worked successfully in the past. Do to a router failure, cable company installed a new router. A colix gigaspire. I have tried multiple times to setup the extender after a factory reset. Th...
Sep 26, 2021Guru - Experienced User
When you're setting it up, are you using WPS?
What actual router model is it?
- Texasdave88Sep 26, 2021AspirantGigaspire gs4220e
I have tried WPS, no success
Used GUI over WiFi no success
On my laptop and on my iPhone
Used GUI over Ethernet cable between ex2700 and lapptop
Thanks
