Unomimous
Apr 05, 2018Aspirant
Cannot regester Netgear N300 DGN2200
I bought the router at a thrift sale. I can't activate the router because it's still regestered to its previous owner and NetGear won't let me re-regester without the origional owners info. How do I ...
- Apr 05, 2018
> [...] the router won't put out any wi-fi. [...]
> [...] As usual, showing actual actions with their actual results (error
> messages, LED indicators, ...) can be more helpful than vague
> descriptions or interpretations.
Still true.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Settings".
Reset the router. That should restore the router to the settings on
the product label. Then, if you still can't get connected to the thing,
then report what you're actually doing and seeing, not what you think itall means ("can't activate", "the router won't put out any wi-fi").
What, exactly, is telling you that "the router won't put out any
wi-fi"?
Bear in mind that there may be a good reason that the device was in a
thrift sale.
antinode
Apr 05, 2018Guru
> I bought the router at a thrift sale. [...]
Ok.
> I can't activate the router [...]
What, exactly, does "activate the router" mean to you? "can't" is
not a useful problem description. It does not say what you did. It
does not say what happened when you did it. As usual, showing actual
actions with their actual results (error messages, LED indicators, ...)
can be more helpful than vague descriptions or interpretations.
https://community.netgear.com/t5/x/x/m-p/1533081
antinode
Apr 05, 2018Guru
Still true.
Settings".
wi-fi"?
thrift sale.
