Lukaka's avatar
Lukaka
Tutor
Aug 12, 2017
Cannot set qos by device
hello, I am trying to set qos rules by device for my xboxone but each time I do it just resets. I click set by device, (I've tried then setting the priority for the Xbox as highest now, as well as ju...
  • DexterJB's avatar
    Aug 28, 2017
    Hi Lukaka,
    After you select the XBOX and set the priority to High then click on Add, the XBOX should appear on the QoS rules box. When you click on Apply and go back to the same page, the XBOX should remain on the QoS rules box.
    Dexter
    Community Team
