Jeff____
Jul 28, 2021Aspirant
Cannot setup Obi 2200
I bought this a year ago and due to COVID and general life things I never got around to setting this up. Now I desperately need it as one half of the house is pretty much zero WiFi. Every time I unplu...
michaelkenward
Jul 29, 2021Guru - Experienced User
Your footer says you have the CBR40. That is a Cable Modem Router. If so, how are you getting the Internet without this modem?
The "Orbi 2200" in your subject is no help in pinning down the model number of your device.
Jeff____ wrote:
The router and modem are 100% fine as they’ve been replaced recently ....
So what are these "router and modem" devices?
If you really do own the CBR40, then you may need some special configuration. Or you just have something that isn't going to work with your existing kit.
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
- Jeff____Jul 29, 2021AspirantI think it’s this actually sorry I’ve never had to post here before
- michaelkenwardJul 29, 2021Guru - Experienced User
No need for apologies. We just need to know what we are talking about.
How about details of the modem and router?
