mphegge64
Aug 05, 2023Aspirant
Cannot update the firmware on AC6700 v2 - will not allow .img file
AC6700 v2 Nighthawk. First, router does not respond when try to connect via the iOS app. That is worthless. Download and try to use web interface but is doe not accept the .img file from Netg...
microchip8
Aug 05, 2023Master
Which router model? AC6700 is not a valid NG model. They start with Rxxx
Are you sure you have the correct firmware for your model? On download page you can select which router version you have (v1, v2, v3, etc)
- mphegge64Aug 05, 2023Aspirant
