philly40
Apr 03, 2018Tutor
Cannot upgrade firmware R6300v2
Can not get this new firmwear to update. already tried to manually update and I get this error...Firmware is invalid and I know it's not. rebooted, downloaded another copy of firmware version 1.0.4.2...
- Apr 05, 2018
Did Google search of there web site with the name of my model and the firmwear that was on it which was the CH ver. re flashed it with the same ver. they had for my model... that had my router starting up with there dd-wrt program did a firmwere upgradeon the router with there program, then I had the new firmwere from Netgear on my computer uploaded through the dd-wrt program. Once it put the new fimwear on I unpluged the router for 5 min. pluged it back in waited anouther 5 push the reset... signed on this time and netgear router page came up with the latest firmwere from them on it...so there firmwere remove dd-wrt.
michaelkenward
Apr 04, 2018Guru - Experienced User
I assume that you are not making the common mistake of assuming that you can upgrade the R6300v1 to R6300v2 with a firmweare update. That has happened before.
(The label will probably say R6300 if you have R6300v1.)
Different hardware. Different firmware.
What happens if you invite the router to find new firmware?
philly40
Apr 04, 2018Tutor
It's R6300 V2 and the auto upgrade tells me no firmwere update avalible
