Cobra1365
Jul 23, 2017Aspirant
Canon MG3620 Wireless Printer Connectivity Issue
I just purchased a new Canon MG3620 wireless printer and have followed all of the set up steps but our iPads will not "find" the printer. During the printer setup, it recognizes and signs on to the ...
- Jul 25, 2017
My son called this evening and fixed it in ten minutes. It was a router security conflict.
ElaineM
Jul 24, 2017NETGEAR Employee Retired
Welcome to the community, Cobra1365
Are your iPads and all other devices connected to the same network as the printer?
Did you successfully connect the printer to the wireless router?
http://ugp01.c-ij.com/ij/webmanual/Tutorial/MG3600%20series/EN/TRL/trl-0003.html
- Cobra1365Jul 24, 2017Aspirant
Yes, both ipads are connected to the same network.
When I went throught hte set up for the printer, it says the printer connected. But, neither iPad will recognize it and when I go into the Router settings, it does not show it.
- ElaineMJul 24, 2017NETGEAR Employee Retired
Check to see if the printer has an IP address from the router.
From the printer settings, you should be able to see if the printer has an IP address.
Once you have it, verify if you can ping that IP address. You will need to open a command prompt in order to ping the IP address.
The Printer User Interface shows 192.168.1.11 as the printer IP Address. But, when I go into the Router Interface, and select "attached devices" it does not show that IP address.
I will try pinging it when I get home this evening.
