xander710
Jan 14, 2016Aspirant
cant acces admin homepage of router
I cant acces the admin page of my router. i've tried this: 192.168.0.1 192.168.1.1 www.routerlogin.net www.routerlogin.com, i used google, internet explorer... router model: wndr4500 Can you help ...
- Jan 14, 2016
Did you assign a static IP address on the computer?
If you have set it on static, put it back on Obtain an IP address automatically.
Both IP's should be in the same range.
It's recommended that you access the admin page of the router using a computer that is directly connected to the router.
xander710
dont work he say: this webpage is not avaiable
regards,
Xander
ElaineM
Jan 14, 2016NETGEAR Employee Retired
What was the IP address and default gateway?
- xander710Jan 14, 2016Aspirant
my default gateaway is 192.168.0.1 my ipv4 is 192.168.121
- ElaineMJan 14, 2016NETGEAR Employee Retired
