LuckyC14
Nov 10, 2023Aspirant
Can't access admin page
Setting up the router to be an access point, provided it with static IP settings, then after it reboots to apply changes I cannot access the admin page anymore. The WiFi is on and working but I can't...
LuckyC14
Nov 13, 2023Aspirant
"It is a good idea to allocate an IP address to an AP to make it easy to find. But it has to have an address that is familiar to the router."
Yes, it is all in the same subnet, and using IP's that are open and the main router will recognize. (configured like the other dozen that are working). Note that the IP address assigned to the access point is able to be pinged. And from the original post's image of the browser, you can see that a device is recognized at the other end of that IP just not able to access the administration page.
"Your first message tags the R6400. Your screenshot shows the R6050."
I noticed that and knew you would mention it. Yes, we do have a few different models, but the differences shouldn't make much of a difference in this case. I found an operational one with the same model and is attached.
It is more beneficial for us to have statically assigned IP addresses for our access points. Without having to use an app I am just looking for a solution to access the admin page via web browser using said IP addresses. Apps like these may be convenient for lay users, but more often than not seem to give me more grief than their worth.
We will be swapping out our whole network for different devices soon anyways. This was just a "simple" thing I should be able to access on a Netgear router, and I moreover just wanted to know if it is something I am doing wrong or testing my faith in the company and its products.
michaelkenward
Nov 13, 2023Guru - Experienced User
Not even the R6400. The screenshot shows R6400v2.
The exact model can make tall the difference as you would know if you hung around here for a while.
Yes. I like to use a fixed IP address. (Fixed on the AP rather than reserved on the the host router, although both work.)
You have been offered a painless, easy and safe alternative that might be a lot quicker than worry away here.
The choice is yours.
A love the "lay users" bit. Worrying though,
- LuckyC14Nov 15, 2023Aspirant
I'll just surmise your response a little..
"Yes, the router should have the functionality to do what you are attempting, however I do not have a solution to your exact issue so I will insult you and provide you with other "fixes""
Yes, version numbers can make big changes, but NOT for something as simple as accessing a administrator web page for a router. If it does, then it is not the product I'm looking for.
Anyway, like I said, we are switching to all different networking devices anyway so
- michaelkenwardNov 15, 2023Guru - Experienced User
Surmise is the right word there. You certainly haven't summarised what I wrote.
