JimmyW
Nov 09, 2017Luminary
Can't access high band with Samsung TV
I can access my WNDR4300v2 router with my Samsung UN65KS TV, if I connect to the 2.4GHz band. However, I cannot connect over 5GHz. I contaced Samsung support, and they have no idea of what I'm talk...
- Nov 17, 2017
5 GHz is faster than 2.4 GHz but has a shorter range.
If 2.4 GHz works, and is fast enough, fine.
antinode
Nov 09, 2017Guru
Not amazing. Many devices, especially ones without a need for a
high-speed network connection, support only 2.4GHz.
Why do you care?
JimmyW
Thanks. Maybe I shouldn't care. I thought that it would be more reliable for streaming video. Is it?
- antinodeNov 09, 2017Guru
> [...] I thought that it would be more reliable for streaming video.
> Is it?
Define "reliable". 5GHz radios can move data faster than 2.4GHz
radios, but if the 2.4GHz hardware is fast enough, then switching to
5GHz would gain nothing but cost. Radio propagation depends on many
things, but, generally, 2.4GHz has a longer range than 5GHz. If you're
at the fringe of 2.4GHz reception, so that your data rate starts to
suffer, then you may already be beyond the useful range for 5GHz.- JimmyWNov 09, 2017Luminary
Thanks again. I'm nowhere near the fringe of reception. I believe, however, that the 5GHz provides more bandwidth, so if I have 5 devices using the router at once and streaming large files, wouldn't the 5GHz offer an advantage?
> [...] 5GHz provides more bandwidth, so if I have 5 devices using the
> advantage?
The size of the file doesn't matter if you're streaming, only the
data rate. (You're not trying to transfer the whole thing as fast as
possible, only to keep up with the demand.)
5GHz might be better, if you're really bandwidth-limited. The
question would be how much bandwidth you really need to serve those
devices. I don't know. Based on some Roku information, I'd expect
something less than 4Mb/s to keep anyone happy. I haven't run the
experiment, so I know nothing, but I'd expect to be able to squeeze
20Mb/s out of almost any 2.4GHz radio/router (if the WAN connection can
do it, too).
https://forums.roku.com/viewtopic.php?t=101059
I assume that that refers to a 1K device. I'd expect 4K to raise the
requirement.
Of course, if the TV does only 2.4GHz, then it wouldn't matter how
much better 5GHz would be (until you get your next TV).
