Italiangen2021
Sep 27, 2022Aspirant
Can't access my account AC1750 R600v2
I am besides myself with trying to access my account. Sometimes it asks me to change my password but it keeps taking me back to reset the password. I'm totally confused by the different accounts and passwords. It says that I've successfully changed the password and to sign in using the small green link.
There is a Netgear account and a router account user name and password.
Please help
PeterD
Join the club.
Those are very different things.
If your "router account user name" is how you get into the browser graphical user interface (GUI), it s local to you. Netgear has nothing to do with it. You don't need Internet access to get anywhere near it.
Sometimes it asks me to change my password but it keeps taking me back to reset the password.Hard to know what you see, but there is one common theme.
Netgear makes life interesting by having all manner of passwords. There is the one into the router's controls, then there are those to get into the router's wifi, and then there any that you use to get into this Community and/or MyNetgear.
Different passwords pop up at different times, depending on how you connect to the device and where you are trying to access from, your local network or somewhere else on the Internet. (Previously known as Remote Access, that's now called Anywhere Access.)
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The problem with resetting the password is you have to meet the minimum requirements or it'll keep making you try to change it.
requirements:
10 characters
at least: 1 special character, 1 number, 1 capital letter, 1 lower case lettter
Join the club.
