ArtieJJ
Feb 15, 2016Aspirant
Can't access routerlogin.net/.com after factory reset, Model: R6200
I factory reset my R6200 and I can get the IP 192.168.1.1 via LAN plug in but oddly in the Windows network adapter screen it displays my "old" network name. I can't access the routerlogin.net/.com p...
- Feb 17, 2016
Yes I am running Kaspersky. I'll try that next. Thanks for the feedback!!
TheEther
Feb 15, 2016Guru
Redo the factory reset, but this time disconnect all cables except power. Wait for the reset to complete, then connect a single computer to a LAN port. The computer should receive an IP address in the 192.168.1.X subnet. Try routerlogin.net or 192.168.1.1.
- ArtieJJFeb 16, 2016Aspirant
This didn't work either. I still got DHCP 192.168.1.1, I can ping it, but can't access either the IP or routerlogin.com/.net.
- TheEtherFeb 17, 2016Guru
You wouldn't happen to have Kaspersky Antivirus installed? For some reason, it simply doesn't like routers. You may have to temporarily uninstall it, or try the suggestion in this Netgear article (link).
- ArtieJJFeb 17, 2016Aspirant
