JNMADISON
Feb 23, 2022Tutor
Can't access routerlogin.net
Hello, I am unable to access the site routerlogin.net in order to install firmwre for my WNDR3400v2 router. I keep getting instructed to clear my browsing history--whch i have done "to t...
- Feb 23, 2022
Glad it worked!
If you mark it resolved, it helps prevent others from trying to fix it too :)
Feb 23, 2022Guru - Experienced User
what modem/gateway is the router connected to?
have you tried the ip address?
The default is 192.168.1.1
and if that was in use the fail over is 10.0.0.1
- JNMADISONFeb 23, 2022Tutor
hello,
of course i understand you're good hearted people trying to assit users. i've done that in non-tech forums. thank you so much for your time.
the modem: Arris Surfboard SB6141
i am sorry--i don't understand the rest of your post. would i type that IP into the URL bar?
thanks again.
i tired that and it worked. thank you so much for your generoous help! i will write that down. iw ish i'd hav eknown that--now i have to re-enter all my passwords etc to pages i go to. taking forever to look them up. i have never, ever, ahd a trouble issue be resolve dby clearign cookies/cache/browsing history. lesson learned. :)
thanks again! have a great one.
- plemansFeb 23, 2022Guru - Experienced User
Glad it worked!
