JNMADISON
Feb 23, 2022Tutor
Can't access routerlogin.net
Hello, I am unable to access the site routerlogin.net in order to install firmwre for my WNDR3400v2 router. I keep getting instructed to clear my browsing history--whch i have done "to t...
- Feb 23, 2022
Glad it worked!
If you mark it resolved, it helps prevent others from trying to fix it too :)
Feb 23, 2022Guru - Experienced User
what modem/gateway is the router connected to?
have you tried the ip address?
The default is 192.168.1.1
and if that was in use the fail over is 10.0.0.1
JNMADISON
Feb 23, 2022Tutor
hello,
of course i understand you're good hearted people trying to assit users. i've done that in non-tech forums. thank you so much for your time.
the modem: Arris Surfboard SB6141
i am sorry--i don't understand the rest of your post. would i type that IP into the URL bar?
thanks again.
- JNMADISONFeb 23, 2022Tutor
i tired that and it worked. thank you so much for your generoous help! i will write that down. iw ish i'd hav eknown that--now i have to re-enter all my passwords etc to pages i go to. taking forever to look them up. i have never, ever, ahd a trouble issue be resolve dby clearign cookies/cache/browsing history. lesson learned. :)
thanks again! have a great one.
- plemansFeb 23, 2022Guru - Experienced User
Glad it worked!
