jcalvert
Apr 13, 2025Aspirant
Can't access single website
I am unable to access https://safetechhawaii.com. Can't browse to it, can't ping it, and traceroute fails. The router is not using any site blocking. I am using ethernet connection only, not wifi....
michaelkenward
Apr 14, 2025Guru - Experienced User
jcalvert wrote:
We have determined that this is a bug in the firmware.
How?
jcalvert
Apr 14, 2025Aspirant
I am filing the bug report right now, using the Nighthawk app for Android, as I was directed by Netgear tech support today.
What I found is that the router is misidentifying IP addresses of the form 192.16N.X.Y as private (local) IPs. It should be looking for 192.168.X.Y, but it looks for 192.16N.X.Y. So it appears that when an IP has any value of N, 0-9, the IP will be recognized as local, and the routing then fails. Any website with an IP like this will be inaccessible.
- FURRYe38Apr 14, 2025Guru - Experienced User
Can you provide a screen capture of this 192.16N.X.Y?
Does this appear on the routers web page under Advanced tab/Setup.LAN setup?
Have you attempted a factory reset and setup from scratch and use the routers default LAN IP address of 192l.168.1.1 to see if this helps any? https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- jcalvertApr 14, 2025Aspirant
It's a bug and Netgear now has the bug report. They should figure out a better way for users to submit bug reports! I was caught in a laughable loop trying to shake my phone hard enough, and then supply the URL to my bug report PDF before the Nighthawk app timed out once again. 🤣
- jcalvertApr 24, 2025Aspirant
I have given up on Netgear customer support—absolutely horrible. Router is EOL so no more firmware updates. Amazon gave me a refund.
