bp11
Dec 14, 2021Follower
Can't change password on router
I am trying to login to routerlogin.net and the screen that says 'admin' doesn't come up. I want to change the wifi password on the router but if I can't login to the router I can't do this. all...
michaelkenward
Dec 15, 2021Guru - Experienced User
How are you trying to login to the router?
Wifi? Wired? App? Browser?
Which password? Router or wifi?
Tell us what you are doing and what happens.
all the informatino just keeps taking me to the Netgear site and there's never an 'admin' screen to login to.
There is no "Netgear site". It is just a way into the graphical user interface (GUI) that controls the WNR1000v3.
What is the modem. if there is one, in front of this router?
