newmguy
Dec 20, 2016Guide
can't change timezone on R5060
I have read that the timezone setting is under Advanced/Security/Schedule. However schedule is greyed out. Any advice? I set the unit up as an access point only and I want to turn off the wifi at...
- Dec 21, 2016
Not 100% sure this will work, but you could try switching back to router mode to set the timezone. Then switch back.
A workaround is to subtract three hours to the times in the schedule to compensate ...
Dec 21, 2016Guru - Experienced User
newmguy
Dec 22, 2016Guide
Yes I already tried that last night, its working. Thank you
Switching back to router then back again worked, however it was difficult to login afterwards. I had to try 2 -3 times.
