adamsdr3
Feb 24, 2016Aspirant
Can't Configure Internet
I bought a new modem and I'm having trouble getting it to connect to my existing router. Everything was fine before I installed the new modem. Router isn't even detecting the internet connection from...
- Feb 26, 2016
I got it to work. This is going to sound really dumb....
I turned both the router and the modem off and removed the ethernet cable. I turn just the modem on with nothing but the coax and power cord attached. I waited for 2 minutes for the modem to completely initialize. Then I ran the ethernet from the modem to the router, turned it on, and wated for the router to initialize and I was good to go.
michaelkenward
Feb 25, 2016Guru - Experienced User
Which modem, which router?
What is plugged in where?
- adamsdr3Feb 25, 2016Aspirant
The modem is a Motorola MB7220 and the router is a netgear WNDR4300v3. Physically, everything is connected correctly. There's a coax cable from the wall to the modem and an ethernet cable from the modem to the router. The WiFi network is there, but I haven't been able to configure the router. Netgear's network genie doesn't detect the connection.
I should also note that the issue HAS to be the router because I can get a connection on my laptop with an ethernet cable directly from the modem. I cannot get a connection with an ethernet running from the modem to the router and an extra cable from the router to my computer.
- michaelkenwardFeb 25, 2016Guru - Experienced User
This isn't really the best place to get advice on Motoral modems, but let's guess what might be going on here. Did you read page 12 of the manual? Where have you connected the cable from the mode to the router? It should be the yellow (WAN) socket, not the Ethernet (LAN) ports.
adamsdr3 wrote:I should also note that the issue HAS to be the router because I can get a connection on my laptop with an ethernet cable directly from the modem.
This does not follow. The two may be working as designed and fighting among themselves to do what you have told them to do. For example, there may be a conflict in the way in which these two boxes are handing out IP addresses. You may need to disable the DHCP Server on the Netgear box, or on the modem.
This is just guesswork on my part, based on a bit of experience. Have you asked your ISP how to set up equipment on its system?
