adamsdr3's avatar
adamsdr3
Can't Configure Internet
I bought a new modem and I'm having trouble getting it to connect to my existing router. Everything was fine before I installed the new modem. Router isn't even detecting the internet connection from...
  • adamsdr3's avatar
    adamsdr3
    Feb 26, 2016
    I got it to work. This is going to sound really dumb....
    I turned both the router and the modem off and removed the ethernet cable. I turn just the modem on with nothing but the coax and power cord attached. I waited for 2 minutes for the modem to completely initialize. Then I ran the ethernet from the modem to the router, turned it on, and wated for the router to initialize and I was good to go.
