adamsdr3
Feb 24, 2016Aspirant
Can't Configure Internet
I bought a new modem and I'm having trouble getting it to connect to my existing router. Everything was fine before I installed the new modem. Router isn't even detecting the internet connection from...
- Feb 26, 2016
I got it to work. This is going to sound really dumb....
I turned both the router and the modem off and removed the ethernet cable. I turn just the modem on with nothing but the coax and power cord attached. I waited for 2 minutes for the modem to completely initialize. Then I ran the ethernet from the modem to the router, turned it on, and wated for the router to initialize and I was good to go.
adamsdr3
Feb 25, 2016Aspirant
Everything is connected correctly because all I did was move the coax cable and the Ethernet cable from the back of the old modem to the new modem. I didn't change anything on the router. I checked with my ISP and everything is good on their end. It's just the router with the modem that I'm having trouble with.
As for disabling DHCP, I can't access the routers configuration settings because I did a factory restore and I'm unable to configure the routing to even get into the settings.
- michaelkenwardFeb 25, 2016Guru - Experienced User
adamsdr3 wrote:
As for disabling DHCP, I can't access the routers configuration settings because I did a factory restore and I'm unable to configure the routing to even get into the settings.Looks like you have a network configuration issue.
Unless you went into some heavy configuration changes, a factory reset just changes the username and passwords
I'll step aside and let the real experts step in.
- Retired_MemberFeb 25, 2016
first push and hold reset until power led flashes, then use defaults
log into router with wired pc ( same as when you verified modem by direct connection ) select setup....internet setup....use PC Mac Address
reboot modem and router
- adamsdr3Feb 26, 2016Aspirant
