Momof3boys88
Dec 26, 2016Aspirant
Can't connect 3DS to Router
Hi can anyone help me connect a Nintendo 3DS to my Netgear N600 router? It is model number WNDR3400. When I attempt to setup a connection the 3DS finds an access point but then can't connect due to e...
- Dec 27, 2016
I think you might be using simplified termology that is incorrect. NAT doesn't need to be off, NAT filtering just needs to be set to open. NAT is the routers ability to turn a public IP into private IP and visa versa. If you actually turned this off, your internet would stop working. NAT filtering refers to SPI used in the routers firewall. However turning off NAT filtering turns off the firewall for your entire network, not just the 3DS, which is a security concern.
Instead, I would suggest putting the 3DS into the router's DMZ. First you would need to set a DHCP reservation for the MAC address of your 3DS. See page 76-77 of manual to see how. This will make it so the same IP is assigned to the 3DS every time it connects. Then put that IP into the DMZ. See page 80 for more info on the DMZ. This will allow the 3DS to bypass the firewall, and you should be able to put NAT filtering back to on/secure.
JamesGL
Dec 27, 2016NETGEAR Employee Retired
Hi Momof3boys88,
Gaming consoles such as Nintendo, Xbox and others requires for NAT to be off. It restricts the connection to the server that is why you are unable to have connection from Nintendo.
Trikein
Dec 27, 2016Luminary
