Ardose's avatar
Ardose
Can't connect my WNR2000V5 to my ISP
My ISP is COMWAVZ from Watch Communications. The service is provided from an RF antenna/modem outside. It works fine on my PC. But, when I connect the router, it won't work. The router says the signa...
  • Ardose's avatar
    Ardose
    Jul 07, 2016
    Yes. It was defective and those jerks at Walmart put it back on the shelf. I made a special trip this afternoon to take it back. This time, I made them open the package and I made sure it was new. I brought it home, hooked it up and what do you know, IT WORKS.
