Ardose
Jul 05, 2016Aspirant
Can't connect my WNR2000V5 to my ISP
My ISP is COMWAVZ from Watch Communications. The service is provided from an RF antenna/modem outside. It works fine on my PC. But, when I connect the router, it won't work. The router says the signa...
- Jul 07, 2016
Yes. It was defective and those jerks at Walmart put it back on the shelf. I made a special trip this afternoon to take it back. This time, I made them open the package and I made sure it was new. I brought it home, hooked it up and what do you know, IT WORKS.
ElaineM
Jul 07, 2016NETGEAR Employee Retired
Ardose Sounds like you got a defective unit.
Again, any model from our router product line will work with the connection that you have.
See this link to choose from our wide selection of wireless routers.
Ardose
Jul 07, 2016Aspirant
- ElaineMJul 07, 2016NETGEAR Employee Retired
Glad that it's now up and running!
