marjay502
May 18, 2021Follower
Cant connect to C6300
I have the c6300 and Im trying to get into it to use the dual frequecy mode becuase my video door came doesnt connect to 5mhz but 2.4 How can i get into the modem to change that. Ive tried routerlogin.com and .net and the IP address and the site doesnt work.
Do I need to do a full reset to get in a config that setting
1 Reply
what error are you getting?
Have you tried a different browser/pc?
If you pull up a command prompt on a windows pc, type "ipconfig" the default gateway should be the ip address.
You can also try 192.168.100.1
